update 18v3 sip problem
mcnick50
hello,
i have many installations in Greece with OTE sip trunk. with 18 v2 everything works fine. when i update to 18v3 the sip shows registered but i get 404 when i try to call and no incoming calls. when i click refresh registration starts to work for a while and again the same problem. all installations are local with windows server 2022.
Unless OTE is a supported provider, your best be is to start troubleshooting with OTE support. Video below for v16 but the concepts are the same.
Under Settings -> Advanced- Network is it set to dynamic ? If so set it static - 3cx are going to release a fix to resolve this issue
Reactions: AWS2P
Other SIP providers seems to be affected in U3 , seen posts about OVH too, what Saqqara posted above is a 3CX Staff workaround, so it should save you until a fix is available.
i have dynamic ip
Reactions: YiannisH_3CX
@mcnick50
As mentioned setting your IP to static should resolve your issue until the fix comes out. If your IP changes frequently and you can't wait then contact me through a p.m. and we will see how we can assist you sooner.
YiannisH_3CX, i have downgraded to v2 to all my clients until the fix is out​
does the latest udate fixed the problem?
Senergia
