Update Extensions using .CSV error V20
Elijah Metherd
Good Day,
I'm trying to bulk update extensions using a CVS file and I keep getting an error that states the extension already exists. Version 20.0 Update 0 (Build 1620 Release). I've tried removing empty columns, but nothing seems to work.
Regarding your question, you can not import extensions via CSV if they already exist on the system; the CSV import feature is for importing new extensions. It cannot be used to update existing ones.
It would be nice if it could be used to update. It would be a lot easier then going into every extension to tick a check box.
grahamaskew
