Solved Update Multiple Phones simultaneously
JoeB
Forum User
We have a site with 38 phones, all in need of firmware updates. I can try to do it piecemeal during the day, but could
probably knock them off quicker, and without disrupting anyone, after hours. The question is how many updates
can be kicked off at once? To some extent this would be determined by their local network speeds and configuration,
but from a 3CX standpoint, is there a limit?
3CX Version - Enterprise Annual / 16.0.619
Server OS - Hosted Linux
Is the 3CX Server Hosted and where? - Yes. Cloudco
IP Phone Make/Model/Firmware - Yealink / T29G & T54S / Varies even within same models
Provisioning Method: - STUN
Trunk Provider or Gateway Make/Model - CloudCo
Has the Firewall Checker passed: - Yes
Are custom Phone Templates being used: - No
All you can select per-page of phones can be kicked of at once.
The limit is mostly in the network bandwidth, so if you don't know what your host's upload is and what the phone's network download is, you might want to do small batches.
Try doing 1 device first and see it is successful (because if your FW is too old it may fail altogether).
T29G ROM = ~20MB
T54S ROM = ~25MB
Thanks. I kept it to 2 or 3. I wasn't sure if there was a defined limit, i.e. the server will only do 1 at a time, etc. There were a few dozen, but I got through it.
Reactions: JohnS_3CX
Glad to hear !
footandankle.my3fcx.us
