Update to V18-9A failed with SSL Error
NTSer
After Updating to V18 Update 9A i got the browser Error "ERR_SSL_VERSION_OR_CIPHER_MISMATCH"
No luck with restarting nginx and rebooting the whole Pbx.
I think, there is a SSL Cipher issue? But in the nginx config i did not found anything about SSL Ciphers.
Any others, who facing this issue?
Thanks a lot for reply!
Adrian
Try another browser?
Did you use 3cx certificate or your own?
I tried different browsers - same behavior
I used my own Certificate - we changed id some weeks ago to ECC Certificate.
but i think this is not a issue....?
before updating to v18 U9a everything was working fine.
Is it an RSA certificate? If not, thats your problem and you need to change it.
Reactions: N_G
We had the ECC Certificate in place with the version before v18 U9a
Did something changed in Version 18 U9a regarding SSL Certificate?
I dont know, but i surely know only RSA certificates are working. All other will have this error you mentioned in your post.
Reactions: N_G
OK
Is this somewhere documented?
Requirements for self shipped corporate Certificates?
No, its my own experience with some customers and some posts in the german forum. All working certificates are RSA.
Reactions: NTSer
Thank you for your reply and help!
Reactions: bitn2
ECC SSL Certificates are working well, with changing the nginx "ssl_cipher" Settings:
root@3cx:/var/lib/3cxpbx/Bin/nginx/conf/snippets# cat /var/lib/3cxpbx/Bin/nginx/conf/snippets/50-ssl-protocols.conf ssl_protocols TLSv1.2; # OLD one #ssl_ciphers 'TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-RSA-AES128-SHA'; # NEW one ssl_ciphers 'TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-CHACHA20-POLY1305';
unfortunately, this setting has to be checked and changed after every update of 3cx.
Yes, they are working with manual changes. That is not supported.
saw-nick
