updating from 18.0.5.418 to New 18.0 Update 6 Final 18.0.6.908
totalkitchens
I am trying to update our system to the New 18.0 Update 6 Final, on the update available page it shows this :-
ReleaseNew 18.0 Update 6 FinalOut Of Date18.0.5.41818.0.6.908New 18.0 Update 6 Final Available
but when a download the selected update & it attempts to install, I get an email a few minutes later with the following text in a file:-
Hit:1 http://repo.3cx.com/debian/1806 buster InRelease
Hit:2 http://repo.3cx.com/debian-security/1806 buster InRelease
Hit:3 http://repo.3cx.com/3cx buster-testing InRelease
Hit:4 http://repo.3cx.com/3cx buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
3cxpbx is already the newest version (18.0.6.908).
0 upgraded, 0 newly installed, 0 to remove and 51 not upgraded.
W: --force-yes is deprecated, use one of the options starting with --allow instead.
So from what this file says it is already at that version so does not need to be updated is that correct, but when I tried ealier in the day, I got this txt file attached to an email but nothing had been updated :-
Get:2 http://repo.3cx.com/debian-security/1806 buster InRelease [8,136 B]
Get:5 http://repo.3cx.com/debian-security/1806 buster/main amd64 Packages [70.6 kB]
Fetched 78.7 kB in 0s (225 kB/s)
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up 3cxpbx (18.0.6.908) ...
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
Updating certificates in /etc/ssl/certs...
2 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
Removed /etc/systemd/system/3CXCfgServ01.service.
Removed /etc/systemd/system/3CXAudioProvider01.service.
Removed /etc/systemd/system/3CXMediaServer.service.
Removed /etc/systemd/system/3CXGatewayService.service.
Removed /etc/systemd/system/3CXEventNotificationManager.service.
Removed /etc/systemd/system/3CXPhoneSystemMC01.service.
Removed /etc/systemd/system/3CXSystemService01.service.
Removed /etc/systemd/system/3CXIVR01.service.
Removed /etc/systemd/system/3CXQueueManager01.service.
Removed /etc/systemd/system/3CXHotelModule01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXCfgServ01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXAudioProvider01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXMediaServer.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXGatewayService.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXEventNotificationManager.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXPhoneSystemMC01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXSystemService01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXIVR01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXQueueManager01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXHotelModule01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXPhoneSystem01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXCallFlow01.service.
Removed /etc/systemd/system/3CXPhoneSystem01.service.
Removed /etc/systemd/system/3CXCallFlow01.service.
Updating from Version 18.0.6.908
Loading global scripts...
Loading instance scripts...
Loading instances...
CurrentDbVersion=542
Updating global DB tables...
Applying script for all instance tables
Loading instance parameters from phonesystem_mastertable
Updating instance DB tables...
Replacing parameters
Npgsql.PostgresException (0x80004005): 42601: syntax error at end of input
at Npgsql.NpgsqlConnector.<ReadMessage>g__ReadMessageLong|194_0(NpgsqlConnector connector, Boolean async, DataRowLoadingMode dataRowLoadingMode, Boolean readingNotifications, Boolean isReadingPrependedMessage)
at Npgsql.NpgsqlDataReader.NextResult(Boolean async, Boolean isConsuming, CancellationToken cancellationToken)
at Npgsql.NpgsqlDataReader.NextResult()
at Npgsql.NpgsqlCommand.ExecuteReader(CommandBehavior behavior, Boolean async, CancellationToken cancellationToken)
at Npgsql.NpgsqlCommand.ExecuteScalar(Boolean async, CancellationToken cancellationToken)
at Npgsql.NpgsqlCommand.ExecuteScalar()
at Updater2Db.UpdateInfoExtractor.ExecuteScript(String sqlQuery, String transactionName, Exception& err)
Exception data:
Severity: ERROR
SqlState: 42601
MessageText: syntax error at end of input
Position: 36
File: scan.l
Line: 1119
Routine: scanner_yyerror
Exception data:
Severity: ERROR
SqlState: 42601
Position: 36
File: scan.l
Line: 1119
Adjusting timezone
Linux timezone file path = /usr/share/zoneinfo/Australia/Adelaide
Configuring Linux timezone
Running /usr/bin/sudo /usr/sbin/3CXSetTimezone "Australia/Adelaide"
Current default time zone: 'Australia/Adelaide'
Local time is now: Tue Feb 7 10:28:15 ACDT 2023.
Universal Time is now: Mon Feb 6 23:58:15 UTC 2023.
System.Exception: DB update failed
at UpdaterNx.Program.Main(String[] args)
any help would be great.
Reactions: michalkolacek
It would seem you have made changes to the iso , installed packages or made other changes.... So best do backup and clean restore.
Since you have a very small free instance you best move to startup free
The same problem here :
apt dist-upgrade
Načítají se seznamy balíků… Hotovo
Vytváří se strom závislostí
Načítají se stavové informace… Hotovo
Propočítává se aktualizace… Hotovo
Následující balíky byly nainstalovány automaticky a již nejsou potřeba:
dh-python gnupg-agent irqbalance libbind9-140 libdns-export162 libdns162 libicu57 libisc-export160 libisc160 libisccc140 libisccfg140 liblttng-ust-ctl2 liblwres141 libnuma1 libperl5.24 libprocps6 libpython3.5-minimal libpython3.5-stdlib libsodium18 libunistring0
liburcu4 linux-image-4.19.0-18-amd64 python-pyasn1 python3-distutils python3-lib2to3 python3.5 python3.5-minimal rename runit-helper sgml-base tcpd xml-core
Pro jejich odstranění použijte „apt autoremove“.
Následující balíky budou aktualizovány:
3cxpbx
1 aktualizováno, 0 nově instalováno, 0 k odstranění a 0 neaktualizováno.
Nutno stáhnout 0 B/119 MB archivů.
Po této operaci bude na disku použito dalších 11,3 MB.
Chcete pokračovat? [Y/n]
Přednastavují se balíky…
(Načítá se databáze … nyní je nainstalováno 53454 souborů a adresářů.)
Připravuje se nahrazení …/3cxpbx_18.0.6.908_amd64.deb …
Removed /etc/systemd/system/sysinit.target.wants/3CXFirewall.service.
Rozbaluje se 3cxpbx (18.0.6.908) přes (18.0.5.418) …
Nastavuje se balík 3cxpbx (18.0.6.908) …
0 added, 0 removed; done.
done.
Updating from Version 18.0.5.418
Exception data:
Severity: ERROR
SqlState: 42601
Position: 36
File: scan.l
Line: 1119
Exception data:
Severity: ERROR
SqlState: 42601
Position: 36
File: scan.l
Line: 1119
Adjusting timezone
Linux timezone file path = /usr/share/zoneinfo/Europe/Prague
Running /usr/bin/sudo /usr/sbin/3CXSetTimezone "Europe/Prague"
Current default time zone: 'Europe/Prague'
Local time is now: Thu Feb 2 13:43:34 CET 2023.
Universal Time is now: Thu Feb 2 12:43:34 UTC 2023.
Created symlink /etc/systemd/system/sysinit.target.wants/3CXFirewall.service → /lib/systemd/system/3CXFirewall.service.
Jeremy Hofex
