Upgrade from v18.0 Update 4 (Build 965) to v18.0 Update 5 (Build 418) Missing
Tahir
Anyone able to assist, my self-hosted PBX version does not appear to give me the option to upgrade from v18.0 Update 4 (Build 965) to v18.0 Update 5 (Build 418). The OS version is Debian 10 buster.
Here are a few options:
1. Are you using the management console to update? If you do not see an update available, what happens after you restart the system/services, is it visible again? Do you have auto updates enabled?
2. If you are comfortable with CLI:
- Manually edit the source list and change 1804 to 1805 and re-run the update. (https://www.3cx.com/community/threa...cx-through-command-prompt.116992/#post-541940)
3. But the best option is to simply download a new 3CX ISO and restore a backup.
I hope this helps! Let us know how it goes.
Reactions: Tahir
The OS is showing as Debian 9 - depreciated. I am thinking this may be the underlying problem.
Thanks for the assistance, I logged back in today and the PBX is now showing the updates, strange behaviour but seems it may have just been delayed. Thanks for responding and giving me some ideas to try, really appreciate it.
Reactions: Nathan@Voxtelesys
VR46
