upgrade from v18 to v20 failed
itops-care-bears
hi all, our 3CX is on ver18update31 and I was trying to upgrade to ver20, which failed with the following last few lines:
2024-06-03 04:38:59.720 CEST [29430] LOG: starting PostgreSQL 13.14 (Debian 13.14-0+deb11u1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2024-06-03 04:38:59.720 CEST [29430] LOG: listening on IPv6 address "::1", port 5433
2024-06-03 04:38:59.720 CEST [29430] LOG: listening on IPv4 address "127.0.0.1", port 5433
2024-06-03 04:38:59.722 CEST [29430] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5433"
2024-06-03 04:38:59.726 CEST [29431] LOG: database system was shut down at 2024-06-03 04:38:59 CEST
2024-06-03 04:38:59.733 CEST [29430] LOG: database system is ready to accept connections
2024-06-03 04:39:11.204 CEST [29430] LOG: received fast shutdown request
2024-06-03 04:39:11.206 CEST [29430] LOG: aborting any active transactions
2024-06-03 04:39:11.211 CEST [29430] LOG: background worker "logical replication launcher" (PID 29437) exited with exit code 1
2024-06-03 04:39:11.211 CEST [29432] LOG: shutting down
2024-06-03 04:39:11.329 CEST [29430] LOG: database system is shut down
2024-06-03 04:39:16.627 CEST [29646] LOG: starting PostgreSQL 13.14 (Debian 13.14-0+deb11u1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2024-06-03 04:39:16.628 CEST [29646] LOG: listening on IPv6 address "::1", port 5432
2024-06-03 04:39:16.628 CEST [29646] LOG: listening on IPv4 address "127.0.0.1", port 5432
2024-06-03 04:39:16.629 CEST [29646] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-06-03 04:39:16.635 CEST [29647] LOG: database system was shut down at 2024-06-03 04:39:11 CEST
2024-06-03 04:39:16.643 CEST [29646] LOG: database system is ready to accept connections
2024-06-03 04:47:26.949 CEST [32351] phonesystem@database_single LOG: could not receive data from client: Connection reset by peer
2024-06-03 04:47:26.958 CEST [32788] phonesystem@database_single LOG: could not receive data from client: Connection reset by peer
2024-06-03 04:47:26.962 CEST [32379] phonesystem@database_single LOG: could not receive data from client: Connection reset by peer
2024-06-03 04:47:32.370 CEST [29646] LOG: received fast shutdown request
2024-06-03 04:47:32.371 CEST [29646] LOG: aborting any active transactions
2024-06-03 04:47:32.376 CEST [29646] LOG: background worker "logical replication launcher" (PID 29653) exited with exit code 1
2024-06-03 04:47:32.376 CEST [29648] LOG: shutting down
2024-06-03 04:47:32.395 CEST [29646] LOG: database system is shut down
2024-06-03 04:47:48.704 CEST [550] LOG: starting PostgreSQL 13.14 (Debian 13.14-0+deb11u1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2024-06-03 04:47:48.705 CEST [550] LOG: listening on IPv6 address "::1", port 5432
2024-06-03 04:47:48.705 CEST [550] LOG: listening on IPv4 address "127.0.0.1", port 5432
2024-06-03 04:47:48.708 CEST [550] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-06-03 04:47:48.781 CEST [564] LOG: database system was shut down at 2024-06-03 04:47:32 CEST
2024-06-03 04:47:48.799 CEST [550] LOG: database system is ready to accept connections
::FAIL::
the VM has 2Cores, 4G RAM. Any suggesions what could have caused the failure?
This is not the complete information. Have you checked where exactly it fails?
NetworkActive
