Upgrade T53 from 95.84.0.95 to 96.87.0.16
anonymouse
I've tried to upgrade the firmware for two T53 phones from 95.84.0.95 to 96.87.0.16 but both fail.
Does anyone know the best way to get these firmware upgraded?
Edit: I have also tried upgrading them to 96.86.0.70 but same issue (fails to upgrade).
Please contact Yealink or use their Knowledge Base.
You will need to upgrade step by step, the phone will not allow you to jump to the latest version.
Hi, I have the same problem in the V20 version
Please contact Yealink Knowledge Base
95.84.0.95 to 96.87.0.16 this step is too big (84 -> 87)
So please check Yealink information !!!
Paulo
Thank you so much Paulo :)
Reactions: paulodagraca
thank you so much John i check now
it works thank you so much !!!!!!!
Stephan Eusebe
