upgrade to SP6 from GUI?
SkyFi
Obviously I missed the requirement to upgrade. All I see is the option to upgrade to Beta SP5. There is no SP6 option.
Can I do this from the gui, or ssh only? This is hosted on AWS and the problem is currently I have no ssh access.
Hello @SkyFi
You need to get SSH access to upgrade the PBX to the latest version. You probably have a wrong download link or a wrong repository that is why you are seeing the Beta as available.
I am afraid you need to get SSH access to OVH.
ok.... assuming I get that, what then will fix this issue?
Ok... thank you... .I should be able to do this later. Thanks.
Let us know if you face any issues with the upgrade.
I tried to ugprade but it now shows me the option to upgrade to SP5. But I can't do that because it says license expired.... But my license is valid, but it can't get to SP6 to see it. What repository should I use. I used the upgrade repository you posted.
EDIT
I misread the original post, so my reply didn't make sense. Mods feel free to delete this.
As i mentioned you need to update through SSH, not the management console. Since you can see SP5 you are running the correct repository. Use the instructions for Debian in the following link to update your system. https://www.3cx.com/blog/news/pbx-upgrade-update-6/
laranicole.lucus
