Upgrade to v15.5 SP3 not working
ck1
this is the error i get when trying to upgrade. running debian 9. installed version 15.5.6354.2
Reading package lists...
Building dependency tree...
Reading state information...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
3cxpbx : Depends: unattended-upgrades but it is not going to be installed
Depends: tcpdump but it is not going to be installed
Depends: postgresql (>= 9.6) but it is not going to be installed
Depends: libssl1.0.2 but it is not installable
Depends: libicu57 but it is not installable
Depends: libcurl3 (>= 7.52.1) but it is not going to be installed
Conflicts: libssl1.0.0 but 1.0.1t-1+deb8u8 is to be installed
E: Unable to correct problems, you have held broken packages.
Rollback to 15.5.6354.2...
3cxpbx is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 108 not upgraded.
Are you running the upgrade as sudo?
im just clicking the upgrade button through the gui
how do you run the upgrade through cli
Hello @ck1
Please follow the instruction in the following post and let me know if that fixes your issue. As you are running Debian 9 you will need to replace jessie with stretch in your source list
Hello @ck1
wherer is the post?
gmacinit
