Upgraded to v18 (from v16). Two SBC (Pi4) will not upgrade.
american10
As title says, I upgraded from v16 to v18 and the two SBC (Raspberry Pi devices) are still stuck on v16. I tried to upgrade them via the update section of 3CX. It says updating and then just stays at v16.
Is there a way to manually update to v18 without uninstalling/reinstalling/reconfiguring on the actual Pi?
Unknown, you would have to investigate the Pi devices to even find out.
If you do get access to them though, you can run the command to install the SBC on top of the existing version and it should remember your URL and key.
StevenWillems
