Upgrading 3CX 15.5.15502 to 16
Steven Dewis
Am I correct in that if I wish to upgrade my client's 3CX from version 15.5 to version 16 that I need to take a full backup and then uninstall 3CX from the server and then install version 16 and then restore from the backup.
My client is using a Pro licence, is there anything I should be aware of that could cause issues?
Thanks.
Just to add, move the 3CX backup from the 3CX folder structure.
When installing ver 16, select the option to restore using a 3CX backup - You do not install 3CX and then run the restore.
Check the OS is supported for version 16 - https://www.3cx.com/docs/manual/phone-system-installation-windows/
You can only upgrade, if the license key has active maintenance
bosdorf
