Solved Upgrading from 15.5 to SP6 and after to 16
GhigoBoi
SOHO User
HI, I am trying to upgrade my Google Cloud based V15.5.5 to SP6, and then upgrade to V16, but I cannot find some clear directions. The majority of the post I found says that this should be an option on the Updates page, but my system tells me that it is up to date, I would like to avoid a full reinstall.
My license: Activated Standard 15.5.3849.1
Product: 3CX Phone System Standard SPLA
Version number: 15.5.5
Expiration both License and Maintenance: 12/30/2022
Thanks for your help!
Reactions: YiannisH_3CX
Thanks Cobaltit, so you are confirming that the direct installation is the way to proceed and there is no option from the SW itself? I wanted to confirm and verify this before proceeding. I have read the article you sent me several times, but on other posts I found different opinions.
All done, I am running now version 16.
Thanks for the support
EMMEPICASA
