Solved Upload MOH fails each time
AWS2P
On a new Debian Pbx cloud on AWS lightsail installed with pbxexpress, I face problems with upload attempts for new MOH.
Tried with several files working on others PBx but no way.
when file is supposed to be in transfer, I can see some thin bar in top of screen moving from yellow to blue during infinite time and nothing else.
What can i check?
I'm not an expert in debian so if something needs to be done in SSH, please give some detailled instructions.
thanks
Hi @aws2p
Let's see if uploading is possible at all first. Have you tried uploading some other files to the instance (small files if possible) like a holiday message for example?
- Are uploading via the MOH menu in Settings or via a Queue's settings?
- Are you uploading using Chrome?
- Can you possibly try from a different connection?
Ok and the file that fails, how big is it?
And what is your upload speed there from that PC ?
My bad audio file format was not good, Have re sampled to 8000khz once more and size decrease to 4MB and that timze upload was good
Reactions: NickD_3CX
intoxtech
