Use extensions in a ring group from a bridge
leonardorebelo
I have a master and a slave bridge set up, everything work fine.
I want to add a ring group or extension from the slave bridge on a rule in the master bridge , is this possible?
The idea is : somebody calls for example 0800 05 500 , it goes to a ring group in the master bridge -> if not answer than to a ringroup in the slave bridge.
Is this possible?
There are ways but I wouldn't recommend it.
Specially for ring groups and queues.
Why wouldn't you recommend it?
And can you maybe tell how it's still possible?
Because groups and queues do quick polling, so you don't want that over a bridge. Also, extensions on the slave would never know they are called via a group, and thus apply the regular forwarding rules and not the Group/Queue DNA.
Use a dummy ext on the master that rings mobile simultaneously, set the mobile to the slave ext to ring with the prefix.
Okay, thank you, it worked
Keep in mind that it will cause issues if a slave voicemail answers the call from a master queue/group. Thus why I don't recommend it.
It seems you already sorted this out but I just want to add that you could do this by:
• Creating an RG on Master PBX
• Creating an RG on Slave PBX
• Set Master RG Destination if no answer to Slave RG
Note: The last step you would have to use "Forward to number" and add the slaved RG number with the bridge's prefix.
Reactions: leonardorebelo
Thank you Chris
Reactions: ChrisC_3CX
gmacinit
