Solved User unable to log in but no ip blacklisted
Philein
Hey everyone. One of my users is unable to log in.
The red error message says "the IP is blacklisted," but there are no blacklisted IPs in the admin panel.
I tried to reset their password, but I am unable to do so because the reset password page is behind the login screen.
What can I do?
In this case, the participant's public IP will be on the global blacklist. There is nothing you can do about it other than use a different public IP.
@Philein if they use any "free" VPN tool just remove it and try to connect again.
You can change between wifi and 5G in order to change public ip address.
It was indeed its ISP. Thanks everyone!
Reactions: NikosT_3CX
amazingbv
