Users shows online even if not registered
mirjam.nz
Hi all
We run a 3CX Version 20.0 Update 1 (Build 731 Release).
When our users log out with their Webclient, their status remains active. If a user logged out in status available, their extension remains active in the queue calls are altering. But since no phone is logged on, these calls go nowhere. We do not use Mobile Phone apps, just the Webclient. Reading though different post here, I sounds like a Push notification issue, correct?
For each users we have disabled all the Push notification settings in ALL Call Forwarding Options . . . .
. . . and also disabled it in the in the general settings of their 3CX (PWA) web client.
What do I miss ?
Thanks in advance.
Kind Regards
Mirjam
Does the extension change status?
Yes, we use DND & Available.
But when we log off via webclient the status stays the same. If you logg off in DND your extension shows DND, if you log off in Available, the extension remains Available.
Today, I found this entry in the Event log:
LevelEvent IDDate & TimeSourceDepartmentDetails
Info1003005/07/2024 07:56Web ManagerCallCentreDeleting expired PUSH subscription of extension 3005, device Chrome on Windows
Extension 3005 is now unregistered, which is correct. However, we have 2 other extensions which still show a status, although no device is registered.
The system is updated to the latest version 20 update 2 (build 715)
One user still has this issue. We have re-set her login credentials. All push notification settings are disabled. However, when she logsout of her webclient, the users status does not change to 'Not registered'.
In "Active connections," I can see when user last accessed from. A manual Revoke also does not change her state to 'Not registered'. Any idea what we can check/change ?
Thanks.
Thanks.
"Ring mobile simultaneously"?
Reactions: Vali_3CX
That’s unchecked above.
Reactions: Vali_3CX
Yes, correct. This is also disabled....
What I noticed is that the extension logs in and out from a different IP. This is because her work environment requests to perform certain tasks via a VPN. Could this cause the extension not de-registering correctly ?
But even if I revoke from the System Admin, the extension shows status, although the extension is no longer registered.
UsernameSource IP, UseragentDate createdLast accessed fromLast active onRevoked IP, DateRevoke reason
3006103.139.xxx.xx Chrome 126.0.0.007/20/2024 12:49 PM202.137.xxx.xx Chrome 126.0.0.007/20/2024 8:50 PM222.154.xxx.xxx 07/20/2024Manual
AshleyStokes
