- Joined
- May 14, 2019
- Messages
- 3
- Reaction score
- 3
Hi all, I've been experimenting with this for a while and haven't gotten very far. Maybe some of you can help, or tell me if this is even possible?
What I want:
I would like to be able to use g722 internally and use g711 for outgoing/external calls WITHOUT transcoding.
What I have:
All desk phones are Yealink T46S and are connected to an SBC. The PBX is on AWS. I am using Twilio for SIP trunking.
The problem:
The phones work just fine extension-to-extension with g722, however Twilio only supports g711. When trying to dial out, it appears that the phone-to-PBX leg of the call is g722 and the PBX is transcoding to g711, and this sounds significantly worse that leaving everything with only g711 enabled. If I tick the "Supports Re-Invites" box in the SIP Trunk settings the phones will behave as desired, but any external call that is transferred or placed on hold looses audio.
Is there something else to try?
What I want:
What I have:
The problem:
