Using webRTC to call from company website
Rangel Sardinha
Hi, is there a way to call a Ringing Group from a webRTC client in my company website?
I've tried using web conference in v15.5, but it's not what I was expecting. Did someone have done it?
And click2call?
I suspect that there may be some issues attempting to terminate to a ring group. WebRTC is intended as an audio /video tool, one to one, or a conference. Attempting to do a set-up, when the far end is not "defined" (a specific destination/device), may be a problem.
I'm sure that there will be some other feed-back on this.
I even can’t find where can I terminate a call in a single extension without using the WebMeeting resource. If it was possible to ring a single extension I could use forward after x seconds
Not sure if this is what you are after but in V16 (currently in Alpha) there is a click2chat/click2talk plugin for WordPress which allows you to place WebRTC calls directly to an extension or Ring Group.
Reactions: N_G
As florink mentioned, there is a wordpress plugin for v16 - https://wordpress.org/plugins/3cx-clicktotalk/ If you dont use wordpress we will soon announce how you can use it without. Furthermore, direct HTTP links are available in v16 called Click2Talk for each extension
Hi NIck,
This plugin works great. Now in our website it could work perfect even in IOS safari.
Now we would like to develop a html plugin which could call 3CX extension without wordpress.
When we could see the way you mentioned?
By the way, will V16 comes in new API with IOS and android platform?
BIT Incorporated
