v10 SP2 - MyPhone minimize to tray
clarity2
Gold Partner
I noticed that the MyPhone does now show up in the system tray, but on my Windows 7 it seems that it also stays in the task bar no matter if you click minimize or close.
This is better than the previous version in terms of avoiding accidental exiting, but still would be better if it would actually go into the tray.
Wondering if this is the intended behavior, a bug or still a work in progress? Is anyone else seeing this behavior?
- Bill
No, I thought that and it says it expires in 2012.
This is what I have in the update window:
It is really strange - may be you need to ask 3CX support / sales.
Regards
contact me [email protected] let me see this. Very strange.
Did someone from 3CX ever give you an update or log in to your machine?
With Nicky's help we found the transparent proxy we have was making trouble with the update even when IE was getting the XML definition well from that same machine. Strange as we used it before but I should have though about that.
Many thanks for the help. Now updated. :)
megalmazan
