- Joined
- Jun 6, 2006
- Messages
- 4,865
- Reaction score
- 9,329
Hi All,
I have seen a number of posts about the V14 feature set. Of course a feature set changes with each version and some features get improved or implemented in a different way. Some are simply not used enough or compatible with modern IT requirements and those get removed. Some dont make it into the release build. Here is a short recap of what has changed in v14 and what our plans are for them:
a. Local and External FQDN - We prefer a single FQDN using split DNS but if this is not possible for whatever reason you will be able to specify a different local and external FQDN in SP1.
b. CDR - the old CDR output on the server is gone and will make way for a new web service API which allows you to connect and retrieve CDR records remotely. An application and its source code will be provided. This API will be available in SP2 or SP3 before year end. If you are using an external reporting application it would be good to know what reports you are using since we might implement these in our reporting module.
c. Wallboard - A separate website for the wallboard was too heavy on resources and so we removed it. We are planning a new web API, but in the meantime you can simply take the presence screen with the Queue status and maximize it on a screen? we also plan to add a queue monitor view to a new feature to be called Switchboard which will be an extension of the client.
d. LineIN/OUT - this is an outdated way of doing music on hold considering some PBXs are now hosted or in a private cloud. That said, we might consider a separate app that can be downloaded and installed for on premise systems that insist on this.
Hope this helps
Hope this helps
