V16 Bridge Unregisters and Re Registers
SonnyPeas
Every day, in between the hours of 1AM-6AM every bridge on a multiple of my PBXs unregister and then they reregister moments later, Seeing as the Bridge shows as a trunk, I get emails at 1-6AM saying trunks are down. It's a bit of an anxiety inducer.
-I don't want to turn email notification off as a fix to this, I'm just curious whats causing it.
Which bridge? Your SIP one or an internal one?
Is the SIP provider taking down their service every morning (a reboot?) Is your internet provider? What about a scheduled reboot of your PBX? Power issues somewhere interrupting connectivity?
Bridge over two PBXs using a SBC/Tunnel Connection, I'll look into ISP issues. It weird that not ALL the PBXs on the same Server have said issue
I've been looking into it more, and the moments before the System says the Trunk error, there are A LOT of hack attempts from unknown IPs ,possibly overloading? not sure keeping an eye on it
if it's just few minutes between bridge unregister/ re-register this is probably normal behavior like automatic reprovisionning each 24 hours for extensions.
Ok that's good, it seems to be every about 23-24hrs so that may be the issue, I'm just worried one of these days it will happen during business hours
[email protected].
