V16 Free only allows one outbound call at a time
Greg.Mohr
I installed the free 3CX 16 for a customer, they only need 4 call paths. All worked well for about 2 months and then after the free support stopped, so did the ability to make more than one outbound call at a time. I have verified with the SIP provider we have a contract and can use up to 4 call paths. Not sure what else to check.
Thanks,
Greg
Thanks,
Greg
Settings -> License -> Refresh License.
It should fix the "Free" mode in 3CX.
Also, check your trunk configuration. You can set the limit there.
Reactions: craigreilly
I have refreshed the License at least a half dozen times. I have the trunk configuration set to 4 calls. It still will only allow only one outbound call at a time. The office is getting ticked off.
Put the system in verbose and check the Activity Log when trying to make outbound calls. Also check the Event Log for any errors.
Please provide these:
  • 3CX Version, e.g. Standard Annual 16.0.2.910
  • Server OS, e.g. Debian 9 / Windows Server 2012 R2 / Raspberry Pi
  • Is the 3CX Server Hosted and where?
  • IP Phone Make/Model/Firmware
  • Provisioning Method: Local / VPN / STUN / SBC
  • Trunk Provider or Gateway Make/Model
  • Has the Firewall Checker passed: YES / NO
  • Are custom Phone Templates being used: YES / NO
what does the dashboard say for:
"Number of calls in use" . x/x
The second number is your license size.
0/16 when I try to make second call it only shows 1/16
And when trying the second call, does something appears in the Event Log? Like an error (in red)? And in the Activity Log?
You should see an error message somewhere, even on the phone.
3CX OS v 16.0.4.493 Standard Annual (Trial mode for another 203 days)
Win 10 Pro
Local MFF PC 4 GB RAM, i5
Yealink T-46S phones FW 66.84.0.95
Provisioning is local
Trunk provider is generic SIP ( I have over 50 of these trunks in use on 3CX with other customers)
Firewall checker has passed
No Custom Phone Templates in use.
01/17/2020 11:21:36 AM - Leg L:52.1[Extn:296] is terminated: Cause: BYE from PBX
01/17/2020 11:21:36 AM - Terminated from "Greg Mohr"<sip:[email protected]>;tag=6053a1ce-1e39-4706-b265-fc953be17696 to <sip:[email protected];tag3cx=eb4e3dcd-1063-4f7d-b9bb-0e8ff4d84554>;tag=3c235143; reason: Rejected
01/17/2020 11:21:36 AM - L:52.1[Extn:296] Sending: OnSendResp Send 500/INVITE from 0.0.0.0:0 tid=Pjedba7811-06de-4710-8d58-fa6022345bdb Call-ID=2d5ac7f9-656d-4472-981e-41790af908b9: SIP/2.0 500 Server Internal Error Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---Pjedba7811-06de-4710-8d58-fa6022345bdb;rport=5080 Via: SIP/2.0/UDP [::ffff:47.21.151.xxx]:1892;branch=z9hG4bK-524287-1---tunneltid;rport;tnlid=clnt.0-00241342-5886-407e-ac5f-9cb544caffae_1188295 Via: SIP/2.0/TCP 127.0.0.1:50195;rport;branch=z9hG4bKPjedba7811-06de-4710-8d58-fa6022345bdb;alias To: <sip:[email protected];tag3cx=eb4e3dcd-1063-4f7d-b9bb-0e8ff4d84554>;tag=3c235143 From: "Greg Mohr"<sip:[email protected]>;tag=6053a1ce-1e39-4706-b265-fc953be17696 Call-ID: 2d5ac7f9-656d-4472-981e-41790af908b9 CSeq: 798 INVITE Warning: 499 3CX-PBX "Server Failure" Content-Length: 0
01/17/2020 11:21:36 AM - SendMsg from <sip:[email protected];tag3cx=eb4e3dcd-1063-4f7d-b9bb-0e8ff4d84554>;tag=3c235143 to "Greg Mohr"<sip:[email protected]>;tag=6053a1ce-1e39-4706-b265-fc953be17696
01/17/2020 11:21:36 AM - ~Target=Unknown:97336160xx@(Ln.10000@Generic VoIP Provider)
01/17/2020 11:21:36 AM - Call(C:52) is terminated
01/17/2020 11:21:36 AM - [CM503020]: Call(C:52): Normal call termination. Call originator: Extn:296. Reason: Server Failure
01/17/2020 11:21:36 AM - [CM503016]: Call(C:52): Attempt to reach <sip:[email protected]:0> from Extn:296 has failed. Reason: Server Failure
The last two numbers of the phone # called have been replaced with xx. This is while another call was made from the same extension.
Okay, what does your outbound rules look like?
Also, what format of DID is your provider expecting? Seems like it's sending it in US format (not E164 as most providers).
See here: Target=Unknown:97336160xx@(Ln.10000@Generic VoIP Provider)
@JohnS_3CX
Here is the first call made and put on hold while trying to make the call show above:
01/17/2020 11:21:41 AM - L:50.1[Extn:296] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=Pje5399d53-683f-4de4-855a-cdcc4b62efa8 Call-ID=c18c3829-5c9e-4b1d-b0bd-9e7e3fa70a7b: SIP/2.0 200 OK Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---Pje5399d53-683f-4de4-855a-cdcc4b62efa8;rport=5080 Via: SIP/2.0/UDP [::ffff:47.21.151.198]:1892;branch=z9hG4bK-524287-1---tunneltid;rport;tnlid=clnt.0-00241342-5886-407e-ac5f-9cb544caffae_1188295 Via: SIP/2.0/TCP 127.0.0.1:50195;rport;branch=z9hG4bKPje5399d53-683f-4de4-855a-cdcc4b62efa8;alias Record-Route: <sip:[email protected]:5080;user=proxy;uri=clnt.0-00241342-5886-407e-ac5f-9cb544caffae_1188295> Contact: <sip:[email protected]:5060> To: <sip:[email protected];tag3cx=a96ebb18-befb-48f4-9f89-c06eb7a09392>;tag=a0308e31 From: "Greg Mohr" <sip:[email protected]>;tag=8a03deca-f2b5-4f27-9601-5c92c060ca28 Call-ID: c18c3829-5c9e-4b1d-b0bd-9e7e3fa70a7b CSeq: 23928 BYE Content-Length: 0
First lets make sure you can have more than 1SC.
Call your VM then call another EXT.
If this works, contact your SIP trunk provider and ask them to look in to it.
I have completed that and they indicated that it had been changed to one outbound call path, grrrrr ! That has now been changed to 4 concurrent call paths. Now I can make two outbound calls, but the 3rd outbound call gets a message "You have reached the maximum calls, check with your administrator".
I have re-verified that the simultaneous calls is set to 4 on the Sip Trunks.
How’re you testing?
If you are dialling yourself (external #) then after 2 outgoing you’ll have used 4sc. Your third out will be the 5th.
How’re you testing?
V16 Standard free should be 16SC or 8SC if older than 1 year. Not 4SC so it should work.
Yep, OP already stated it's 16SC if the above is correct. But that doesn't say what the trunk is set to in 3CX.
3K8iMGWviZ
