gigaboy SOHO User Joined Jul 6, 2016 Messages 90 Reaction score 3 Oct 3, 2019 #1 I read that this update requires that I NOT use a self-signed certificate. As a sanity check, will the Lets Encrypt cert I have now work with this update?
Saqqara Bronze Partner Basic Certified Joined Mar 12, 2014 Messages 4,775 Reaction score 1,471 Oct 3, 2019 #2 Use are using a 3CX fqdn - 3cx.us so it will be a Let's Encrypt ssl certificate.
JohnS_3CX Support Team Staff member 3CX Support Joined Jan 4, 2019 Messages 14,566 Reaction score 3,738 Oct 3, 2019 #3 Yep, you should be fine then since your PBX takes care of the certificate for you via Let's Encrypt. You do not have a self-signed one.
