V18 3CX App - Provisioning Failed
Godl1ke
since we updatet to V18 - we cant provisoning with the Desktop App.
The Log's says:
[2022-03-09 13:23:38.004] [warn] (provisioning-process.class) Error: Cannot create a secure cookie from an insecure URL
[2022-03-09 13:23:38.007] [warn] (provisioning-process.class) provisioning failed, reconnects in 5000 ms
Any Ideas whats wrong?
Hi @Godl1ke,
Where is the PC relative to the PBX?
Can you send me the License key in a PM to take a look at?
Did you connect to your webclient over https?
Hi @Godl1ke,
Does the PC have any AV software running? Can you disable it and try again?
I only have the default windows defender activ - disabled it and tried again with the same result, i tried different browser to, i dont realy know why this happens everytime the same error, i also deletet the full directory (AppData\Roaming\3CXDesktopApp), perhaps ngnix or a cert issue?
[2022-03-09 15:40:44.905] [info] (provisioning-process.class) update session was forced
[2022-03-09 15:40:44.906] [info] (cleanup-session.func) cleanupSession
[2022-03-09 15:40:44.912] [warn] (provisioning-process.class) Error: Cannot create a secure cookie from an insecure URL
[2022-03-09 15:40:44.912] [warn] (provisioning-process.class) provisioning failed, reconnects in 5000 ms
i also tried it on different computers with the same result, so this is not a local problem on my device
Reactions: VasilisV_3CX
Can you PM me a new extension's Web Client credentials for me to try on this side?
Hi @Godl1ke,
Can you take a backup WITHOUT the FQDN and License Key, uninstall the PBX, reinstall the PBX and re-enter the license key. Use your backup when reinstalling. Don't change any settings. Let me know if provisioning the Desktop App is a problem afterwards.
Graham Robertson
