Solved V20 AI control features
VoIPTools
3CX MVP
Platinum Partner
With all the AI feature changes, the inclusion of the new 3CX AI option, and the separation of AI features between Pro and Enterprise, I'm a little confused how to manage which recordings are analyzed (transcription, summary and sentiment). Perhaps all three steps fall under the umbrella of "transcription" for recordings? I can see in my Enterprise version under Departments --> Options I can set whether to transcribe voicemails and recordings. And at the user level I can override the Department settings for transcribing. Can anyone describe where and how these features are now configured?
There is no additional switch for analysis, i.e. if recording transcription is enabled, sentiment/score will be also applied after. Provided that it's Enterprise, of course.
Thank you. That was my assumption.
Graham Robertson
