v20 certbot not working
Bergwerk IT
after adding a letsencrypt snippet containing the following to nginx, creating the directory structure and adding a ping.txt file containing "pong" I can reach this at http://3cx.domain.tld/.well-known/acme-challenge/ping.txt. This can be reached per browser using HTTP as well as CURL. However, after installing certbot and setting "webroot-path = /var/www/letsencrypt" in /etc/letsencrypt/cli.ini and running certbot certonly --debug-challenges -v --test-cert --webroot -d 3cx.domain.tld -w /var/www/letsencrypt it fails. This same process works on all other debian boxes we have that is running either Apache or NginX.
Code:
# Configuration file for Let's Encrypt ACME Challenge location
# This file is already included in listen_xxx.conf files.
# Do NOT include it separately!
# This config enables to access /.well-known/acme-challenge/xxxxxxxxxxx
# on all our sites (HTTP), including all subdomains.
# This is required by ACME Challenge (webroot authentication).
# You can check that this location is working by placing ping.txt here:
# /var/www/letsencrypt/.well-known/acme-challenge/ping.txt
# And pointing your browser to:
# http://xxx.domain.tld/.well-known/acme-challenge/ping.txt
# Sources:
# https://community.letsencrypt.org/t/howto-easy-cert-generation-and-renewal-with-nginx/3491
# Rule for legitimate ACME Challenge requests (like /.well-known/acme-challenge/xxxxxxxxx)
# We use ^~ here, so that we don't check other regexes (for speed-up). We actually MUST cancel
# other regex checks, because in our other config files have regex rule that denies access to files with dotted names.
location ^~ /.well-known/acme-challenge/ {
    allow all;
    proxy_redirect off;
    # Set correct content type. According to this:
    # https://community.letsencrypt.org/t/using-the-webroot-domain-verification-method/1445/29
    # Current specification requires "text/plain" or no content header at all.
    # It seems that "text/plain" is a safe option.
    default_type "text/plain";
    # This directory must be the same as in /etc/letsencrypt/cli.ini
    # as "webroot-path" parameter. Also don't forget to set "authenticator" parameter
    # there to "webroot".
    # Do NOT use alias, use root! Target directory is located here:
    # /var/www/common/letsencrypt/.well-known/acme-challenge/
    root         /var/www/letsencrypt;
    try_files $uri =404;
    break;
# Hide /acme-challenge subdirectory and return 404 on all requests.
# It is somewhat more secure than letting Nginx return 403.
# Ending slash is important!
location = /.well-known/acme-challenge/ {
    return 404;
If anyone has any idea how this could happen please let me know.
thx
chuck
funny how audio works on our internal LAN/VPN and not the external address.
