v20 Inbound Rule Mass Edit
alij
Just a general concern I want to voice - I'd be a gem to have the v18 Inbound Rule mass edit brought back in some way.
A recent v20 update ended up having my generic trunk have issues that I had to rectify by creating a new template, and I had to take a considerable time to manually re-assign 70+ did's to a new trunk. All though it was easy to export the current rules - having no way to import back is lame.
I'd hate to do this to my other PBX's that have 100-200+ DID's.
Please note that the CSV must contain only the following fields, with no header row:
  • Column A: DID Number
  • Column B: Destination
  • Column C: Name (optional)
For example, if you want to add the DID +1234567890 to a trunk with a destination of 800, the CSV should contain:
+1234567890,800
If you would like to name the inbound rule (e.g., “IVR rule”), then include the third column:
+1234567890,800,IVR rule
Reactions: fxbastler
Is this documented anywhere? I couldn't find anything that specified that.
Thank you for clarifying.
