V20 Issues - Shared parking doesn't work
ronenba
Using Granstrean 2170
I setup a PBX before upgrading to test,
on V18 established to setup shared parking on Grandstream 2170 but not on GXP2160 ( manually setup)
now on version V20 shared parking give option SP495 - BLF is not on, can place a call but cannot pick it up
must find a solution for customers (we started to migrate from FreePBX to 3CX)
any ideas on how to make Shared parking work?
why we must move to v20? if it is working why to break it?
Hi @ronenba
Change the role of the extension to "receptionist" and check again.
on all extensions? all need shared parking
What is the current version of the PBX?
V20:
1. change it to receptionist
2. setup a line to dial in to this extension
3. setup Shared Parking, i can place the incoming call on parking cannot see (BLF doesnt work)
4. cannot pickup the call after Paked
Reactions: NikolasA_3CX
i setup 2 phones Fanvil X7A with extension 209
and Grandstream extension 599
on Grandstream the BLF is greyout on Fanvil it is on and working
on v18 working fine , on V20 doesn't want to work
No, it is not through SBC
Navigate to the update section, and check if there are any updates to be done, and if there are, upgrade the system and check again.
1.0.11.74 for the phone
did you meant ?
That is correct
ok need to wait after hours, already had issue with the first update ( could not transfer calls to BLF)
Are they router phones? AFAIK 3CX only supports connecting through an SBC/router phone, to 3CX hosted servers.
Of note, v20 update 1 beta 2 came out today so you will likely have two updates to install.
did the update, doesnt work
now BLF stopped working
On-site I am using SBC but it is not working properly, so it is working on V18 but no longer on V20?
so need to start replacing all the phones Grandstream 2170?
I am running a test from my home office, was perfect in V18 now doesn't want to work
restored the PBX to V20 before update 1 beta 2 came out today to get some of the features working (I Hope)
after restoring to V20 before BLF stopped working
rebooted the PBX BLF started to work but the attended transfer is still not working, so I will need to:
1. disable 3CX provisioning
2. on the grandstream force static Blind transfer
unless there is a way to force the Grandstream from 3CX to disable Attended transfer (please do not point me to :
1714434990655.png as it doesnt work)
very odd after restoring from yesterday backup it doesn't show pending updates:
Graham Robertson
