Solved v20 reports to another email-receipient possible (like in v18)?
Dietmar
Hi there,
with the last update the scheduled reports were coming back. Nearly.
Is it in v20 possilbe to send the scheduled reports to another email-receipient (like in v18)?
Thanks.
Dietmar
No.
the only way to do this is to create an extension with an email that is a distribution group.
Dietmar, hi.
So in V20, the report will be sent to the user who schedule/created the report and that is the current design.
Thanks NERO and OlegR_3CX for your fast responses!
So an ordinary user [who should not have higher rights (because of GDPR, privacy, ...)] that is responsible for a dedicated (Hotline-)Queue is no longer able to receive/download his reports as it easily was in v18.
Still I don't get the point of the DOWNGRADE from v18 to v20 ;)
Some options have changed in V20 and your option will be what @Alphabetic suggested, now for the future, we will have more options to come from the report side, however we can't advise if the one you're after will be in the same way as it was.
Thanks both of you for your help.
The new (v20) disabilities are not your personal flops!
You are welcome.
I will close this thread now, as there is nothing much to add here.
Have a nice day
mpeyruchat
