Solved v20 trunks SIP-TLS configuration options missing
benrg
Gold Partner
3CX v20 lacks trunk options to enable SIP-TLS / SRTP.
v18 related options are :
Options / SRTP Mode : Enforced
Options / Transport Protocol : TLS
Options / TLS Root Certificate : certificate file
3CXdevteam, could you please make these options available again in v20 ?
Thank you very much !
SIP TLS is only available on supported trunks that have TLS tested/interoped in v20, AFAIK.
Going through the list, I was not able to find a provider with such SIP-TLS / SRTP options.
Would be nice to recover the ability to tune these options on a per-trunk basis, overriding the default settings.
I am on Version 20.0 Update 1 (Build 731 Release), and if you use Generic trunk and go to the options, you should be able to see this:
Hello @OlegR_3CX
Thank you very much for your reply, you're right, using a Generic (Country) SIP Trunk we are able to configure SIP-TLS / SRTP from Options panel.
Perfect, let's then mark this thread as solved, thank you very much :)
Reactions: OlegR_3CX
Perfect! I'm happy to share the knowledge, and I guess this is what we all do here.
Thread will be closed.
Have a nice day
Reactions: benrg
lastshadow
