V20 U2 Alpha - AI, Microsoft Teams & Admin Control
@AndreasP_3CX thank you it was setup under default project, make sure you change documentation to specify setting up a project. Also no gpt-4-turbo availible just gpt-3.5-turbo which doesnt work. 1718213853699.png
@AndreasP_3CX thank you it was setup under default project, make sure you change documentation to specify setting up a project. Also no gpt-4-turbo availible just gpt-3.5-turbo which doesnt work. View attachment 41920
my list of models is more extensive than the one in your image, did you add a payment option to your account and some credit? Can you try and let me know?
I did add money thinking that was an issue apparently OpenAI doesn't operate on the same timelines as commerce as they took the money but haven't updated my balance... kind of disappointing...
ok credit hit still nothing View attachment 41922
i am assuming you also set up a payment method in the OpenAI portal. Now the API key that you are using, you created it for your new project or was it created for the default project?
Ok it took a bit but is working no reboot of 3cx required... thank you @AndreasP_3CX will now shift back to SharePoint and test.
@AndreasP_3CX that's the good thing about Alphas we flesh out the steps so our clients don't have to thanks for all your help today looking forward to testing...
You are very welcome, let us know if there is anything else we can help you with!
Just one way? That doesnt make sence...
Hi team
Two way does not work. they start to "Steal" the presence of the other. MSGraph seems not to like this so it expects a 1 way presence update. To 3rd party or from.
But I find that one way does makes sense. There are companies that have teams on their desktop only and use 3CX as a phonesystem. So they currently have to change the presence in 2 apps. Now they just need to make it in one only.
And if they have to use 3CX and teams for other tasks, then 3CX can push updataes to teams.
RE Multi Edit - Will be available in the NEXT update. Currently in testing as we speak. So do not worry too much about it.
Hi Team
No reboots of 3CX are required. We just need to wait for very busy openAI to update it's settings..
This applies to credit, config updates, and anything that you setup.
Checking the rate limit discussion as we speak.
@nikolascx took about 2 hours for us from when we started testing to get the emails confirming funding pretty poor turnaround from a company that MSFT holds a 49% stake, and we are using Office365 :)
Added the new ports still not working for the install private web meeting fails at download/install.. 48000-65535
There is no mention of API support and API documentation, is that coming in Update 2 or not? (as the was previously promised)
It is mentioned in the Update 2 Alpha release blog that API will come soon.
I found that it took a bit of time to work after configuration of the Openai end.
Also note it only does new calls, not previously made calls prior to adding openai.
Reactions: illcsales
MSFT can't even add AI to the Outlook app for general use, without a PHD in config.
Reactions: N_G
Should we see the Alpha release available in Admin Console? I am not seeing it yet. Thanks all.
you can input below command to upgrade Update 2(do not run it for production 3CX)
Bash:
echo "deb [arch=amd64 by-hash=yes signed-by=/usr/share/keyrings/3cx-archive-keyring.gpg] http://repo.3cx.com/3cx bookworm-testing main" | tee /etc/apt/sources.list.d/3cxpbx.list
apt update
apt -t bookworm-testing upgrade 3cxpbx
if upgrade failed, also can run below command:
Bash:
apt remove 3cxpbx
apt install 3cxpbx=20.0.2.688
Reactions: nikolascx and N_G
Debian 12 64 bit VM: 4-24 vCPU, 4-16 GB RAM, 50 GB storage, 50-500 Mbps down/200 Mbps-1 Gbps up depending on your usage. More detailed documentation and info will be out at a later date.
Will it be allowed to have a 4K conference and more video participants (compared with the 3CX-hosted MCU)in the private MCU mode?
Reactions: N_G
ARKC
