V20 U6 Release Candidate 2
MichaelB_3CX
3CX Team
Staff member
3CX Support
Last fixes before final.​
Following the successful ALPHA, BETA, and RC1 releases, today’s RC 2 includes last fixes ahead of U6 Final, coming soon.
Updates & Improvements:​
Added​
  • Support for Orange Business Talk (BTIP).
  • The “Queue Answered by Waiting Time” report now inc...
20.0.6.700 RC2 and still turquoise / cyan-blue (2FBBB3) and something like darker cyan-blue (1D8FD2) status colors :(
Reactions: Martin Behrens
"Banners have been introduced in the Web Client" for...?
Installed. No issues seen. Thanks.
Reactions: GregG_3CX and N_G
I'm having an issue on more than one system where even though multi company mode is off, it is still showing up when going to system. It did this in Release Candidate 1 as well, and remains after updating to RC2, it didn't exhibit the behavior prior to Update 6
On our system the beta version showed and upgraded fine, but the RC1 or RC2 don't show.
We are on Version 20.0 Update 6 (Build 700 Beta)
That build version is RC 2, its still technically flagged as Beta since Release Candidates are just mostly complete Beta releases (no new features typically planned, just bug fixes and last minute additions unless we get lucky). The below are all Update 6 Releases and corresponding build versions
3CX Version 20, Update 6 RC2, Build 20.0.6.700, May 2025
3CX Version 20, Update 6 RC, Build 20.0.6.675, April 2025
3CX Version 20, Update 6 Beta, Build 20.0.6.619, April 2025
3CX Version 20, Update 6 Alpha, Build 20.0.6.486, March 2025
see the following page for more info
https://www.3cx.com/blog/change-log/phone-system-change-log-v20/
Yeah wondering that too lol
These are informative banners in Data Connectors. For example if you go into the Data Connector section but the license key does not meet the requirements of that feature, it will state what is required. (i.e "Requires a license for 16+ simultaneous calls.")
In Update 6, the Multi Company section is always available, it is not hidden.
In this section you can now see banners showing what needs to be addressed before the system can be changed to Multicompany mode.
Once these get addressed, you will be able to enable or disable it from this section.
What can we expect for U7 now ? :p
Quick side question, any change there will be also a new 3CX supported Snom firmware 10.1.193.X coming out with the final U6 release? Or in the very near future? Got some low audio issues which is supposed to be fixed in the latest snom firmware.
Installed without issues.
Thank you Team for the hard work!
Oh, doesn't MCM already support a separate phone book for each Department?
Unfortunately it doesn't. It was mentioned it could be included in U6 but there is already a lot of welcomed changes. Fingers crossed U7 sees it :)
Sorry i has question,
Status phone in 3cx admin, how to check status mobile app 3cx online, before can show in status phone.
Thank.
Thank.
Hi Masaki
The Phone App Status cannot be checked because it is launched via Push Notification.
So you can only check the Profile Status. Hope this answers your question.
jb_erp
