KyriacosS_3CX
Staff member
- Joined
- May 8, 2025
- Messages
- 2,207
- Reaction score
- 1,714
Dear 3CX team, thanks for the update, looking great, testing the new features. I noticed one thing on our alpha that is different to stable releases. Maybe that is only on my instance, the call history shows permission errors and the user has to be at least supervisor to see the abandoned queue calls. In the past user permissions were sufficient. Was there a change with regards to the call history or permissions?
Can you check if you have "Abgebrochene Warteschleifenanrufe in den letzten Anrufen für Nutzer, Rezeptionen und Abteilungsadministratoren verbergen " enabled in System > Options > Apps? If yes, then what you are seeing is the correct behaviour.
