V20 - Users can see other people's calls within the same department
Bolz IT
As stated in https://www.3cx.com/docs/manual/access-roles/, the role "user" shouldn't see group calls.
This is not the case in my v20 test instance.
Does this have anything to do with this change?
We cannot change the options for the group(s) the user belongs to.
I realize it's still in beta, but we need to make sure group calls can still be hidden.
We have the exact same issue on our system. Unticking "Calls" in the "View" Tab is not possible
@msychold
so if you are in the department, the roles are predefined there based on the role you have and you can't change them.
If you take the user from that department, you will be able to give the actions you need.
NathanMitchell
