Valcom VIP-204b won't answer call
Colorado VoIP
Gold Partner
Is the 204b registered within 3CX ?
Couple of things to check
Is there an auto answer setting on the 204b
204b - does it have any logs that you can look at
What does 3CX activity log show you
the 204b is indeed registered and happy, wire shark traces show it just not answering the invite. there isn't a specific box to check on the valcom for auto answer, according to their support it should connect the call automatically to the page zone programmed. it's just not.
i have an idea i'm going to try here in about an hour, i need to do something else real quick. this is a hosted system and i think having it talk directly isn't going to work. i'm going to try setting it up behind the SBC as a test.
update to the situation. i told the device to use the SBC as the voip system and not direct to the cloud machine and it answered the call and paged as expected!
Wecare_ITA
