Solved Version key PRO
thiago.lemos@nassautecnol
I can't generate the pro version key to perform tests on the client.
You will need to go to your PARTNER portal. Log in, and go to"Keys".
Select "Assigned Keys" from the drop down menu
From the "More" button menu, select "POC"
Fill in the details
Ok it worked 100%
footandankle.my3fcx.us
