john.cho Forum User Joined Aug 20, 2019 Messages 2 Reaction score 0 Aug 20, 2019 #1 HI Update 15.5.15502 phone does not support Any help would be appreciated.
AWS2P Silver Partner Advanced Certified Joined Jan 9, 2014 Messages 5,077 Reaction score 1,096 Aug 20, 2019 #2 Your phone FW is not supported for use with V15.5 it is for V16 Sp2, this is why you got this red message. why not upgrading PBX to V16 ? if so your firmware will be up to date
JohnS_3CX Support Team Staff member 3CX Support Joined Jan 4, 2019 Messages 14,566 Reaction score 3,738 Aug 20, 2019 #3 Hi John, You will either have to install the firmware that your PBX provides, or upgrade to a newer version of the PBX. Select the phone, and click the +Firmware button to install the correct version.
john.cho Forum User Joined Aug 20, 2019 Messages 2 Reaction score 0 Aug 20, 2019 #4 not upgrade this version15.5.15502 , the phone has support so upgrade V16 Sp2 , support yealink tp19 e2?
AWS2P Silver Partner Advanced Certified Joined Jan 9, 2014 Messages 5,077 Reaction score 1,096 Aug 20, 2019 #5 What do you mean ? you don't want to upgrade to V16 SP2 because you have support on V15.5 ? If you are on paid licence with support you have free access to V16 upgrade, What is your actual licence, STD ? PRO? ENT? annual? permanent? how many SC?
JohnS_3CX Support Team Staff member 3CX Support Joined Jan 4, 2019 Messages 14,566 Reaction score 3,738 Aug 20, 2019 #6 The T19P E2 is supported on V15.5SP6 and on V16SP2 Each of the PBX versions support a different firmware level.
