Video support on Fanvil i31S & Door opener
apitsos
SOHO User
Hi there!
I managed to install and configure a Fanvil i31S Door phone with our 3CX V18. The guide here (https://www.3cx.com/sip-phones/fanvil-sip-doorphones/) is helpful, but actually I found it after doing it myself. The procedure is more or less straight forward and it's not different than any other IP Phone.
After the successful configuration, I was trying to figure out why I am not getting a video call. Finally I noticed that I can see video only on the new/modern "3CX Desktop App". I don't get video on the 3CX Web Client, or on the old 3CX Windows Client, or even on my smartphone (iPhone), via the 3CX App. I get the option for a video call, but I am not getting image.
Any ideas how that could work better and have video on all applications?
As an additional question, is which device would you suggest as door opener, in order to combine it with the Fanvil i31S. Anyone who had experience on that?
Thanks a lot in advance for your prompt attention and all the answers and comments.
With kind regards,
Angelos Pitsos
Regarding your question, the video function will depend on the video codec supported by the device. The Fanvil door phones support H264, which the webclient/desktop app being WebRTC based also supports, although the 3cx app for windows (legacy app) does not and supports only VP8, and H263. The mobile app also only supports H.263, VP8, and VP9.
We, therefore, suggest using the webclient or desktop app.
Regarding this, it's best to take a look at the device manual as it falls outside our scope.
It has some standard wiring terminal types used by common door openers.
You can then send a DTMF to the device and it will activate the terminals, which will then activate the solenoid on your door.
Reactions: apitsos
Hi there!
I would like to thank you both of you for the clarifications. They are much appreciated.
I only wanted to ask both of you, @Charles_3CX @JohnS_3CX if there are plans to implement H264 in the mobile App as well. That would be really nice.
Thanks a lot in advance!
With kind regards,
Angelos Pitsos
Hi there!
With kind regards,
Angelos Pitsos
No plans. Was asked years ago and some licensing stuff makes it undoable.
  • Sad
Reactions: apitsos
Hi @ConceptsWeb,
Sad news... But thanks for your answer anyway!
Greetings,
Angelos Pitsos
Also if using the door phone in an insecure location make sure to use a remote web relay device and not the connectors on the door phone to permit the opening. Otherwise all one has to do is bash the door phone off the wall and connect two wires to open the door.
