Solved Vitelity trunks not registering - V20 U3
mattdarnell
Gold Partner
V20 U3, Enterprise, Hosted by 3CX
Heads up with Vitelity trunks, the template does not work.
The template sets this value as '1' - <field name="RequireAuthFor">1</field>
It needs to be '4' but with hosted systems you can not import trunk XML files.
You need to set it up as a generic trunk and set the 'Type of authentication' to 'Register/Account based'
-Matt
The template is correct as this provider is tested as ip based and not registration based.
You are welcome, keep in mind though that as per announcement here those restrictions for the 3CX Hosted will be removed in the upcoming Update4.
SG_F7
