Hi ,
pbx and SBC are in latest version ? V16.0.2.910 and 16.0.386 for SBC
Do you have confortable bandwith on your internet link ?
Is firewall checker passes green?
What audio codec do you use ?
Call is from deskphone ? DECT? smartphone? WIFI connected?
There was an issue in v15 SBC regarding RTP ports not being available, so please outline your version as above.
Do you have PBX delivers audio enabled/disabled on the extensions in question ?
Also check Windows Firewall is off (if using the Windows based SBC) and ensure the local adapter is in Private mode and not Public (as this will reject requests for unknown sources).
okay i will disable it and testPBX delivers audio on the extensions should not be required when using the SBC, only in remote STUN mode or when call recording (recording funnels traffic through the PBX as standard).
what does you mean by dedicated to voip ?Is your data link dedicated to VOIP ? Your bandwith 6Mb/s is stable all day long or may decrease depending use and hours of day?
How many Phones do you have behind SBC ?
is the link used exclusively for IP telephony? or is it also used for all other uses of the company?what does you mean by dedicated to voip ?
No its dedicated for voip only .is the link used exclusively for IP telephony? or is it also used for all other uses of the company?
is there any guide to understand sbc logs or not ?Since you are using the new SBC you can also set the logging to verbose and check your logs during the times of the issue and see if anything shows up. https://www.3cx.com/docs/3cx-tunnel-session-border-controller/
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
