Voice Input component "number"
PC974
Hello everyone,
I'm trying to work with the voice input component using Google STT/TTS.
I attempted to recognize the user's voice input for a postal code, but I'm facing some issues.
I'm using $POSTALCODE as a hint, without a dictionary value, but Google returns results like "85 500" or "8 5 500", depending on the input.
I need the format to be "85500" so I can compare it with another variable in my script.
Is this possible natively, or do I need to develop a custom C# script? Or perhaps I misconfigured the Voice Input component?
Best regards
Just add a C# script after the Voice Input, to remove the spaces:
return text.Replace(" ","");
or maybe in a CFD expression editor:
REPLACE("8 5 500"," ","")
Thanks ! the Replace Expression works fine :)
DejanMDS
