Voice to text - Same location
JorgeWillianSantos
I want to set up voice-to-text for a client, but I want any response to send the client forward, or at least different responses to send the client to the same location. How do I set up the call flow so that it does at least one of these configurations?
The Voice Input component doesn't force you to go in any direction. It will do the recognition, and tell you what it recognized, and will also tell you if the recognized text matches any of the dictionary entries you specified (if any). Then you need to use a Conditional component to decide what to do with what the user has spoken.
ARKC
