Solved VoiceFlex - Mask Outgoing Number
Saqqara
We have started to use VoiceFlex as it is a supported 3CX hosted provider. Everything is working correct, as per guide - https://www.3cx.com/docs/uk-sip-trunk-voiceflex/
The client is in the process of getting their existing number ported, so we have asked Voiceflex to mask the outgoing number - this is where we are experiencing an issue.
I have asked Voiceflex to mask the outgoing number, but it is not working. When you install VoiceFlex as a provider, it imports the correct template for this provider. I have tried to change some of the outbound parameters but still when dialling the recipient sees the sip number and not the masked number.
Does any one known what parameters I have to change.
Hi @Saqqara
The default template includes all the correct settings for this work so no changes are needed. To present a caller ID that does not belong to your trunk however you may need to activate it from the Voiceflex portal. Your caller ID needs to be set to "PASS-THROUGH" and you need to accept the terms and conditions for the Type 5 presentation number facilities.
Thanks you YiannisH_3CX,
I did not accept the terms and conditions - all working now
Glad to see the issue has been resolved :)
lastshadow
