Voicemail Disabling itself
techguyjason
Forum User
I am having issues for the last couple of days with my voicemail disabling itself. I can go in and set STOP_VM back to 0 and it will work for a few hours. I have restarted the server and services. It continues to disable itself. I dont see anything in event logs. I am on version 16.0.6.641
What are your voicemail settings under Settings - Voicemail Settings. Have you created an extension the same as the voicemail extension number
On the screenshot, you have a the 'System Extensions' is red, you need to investigate this
What other parameters have you changed.
On the screenshot, you have a the 'System Extensions' is red, you need to investigate it.
You may have helped me out. I didnt have the auto cleaning turned on.
Yes, you range out of space, I would also enable 'Email Notification'.
As the server has enough space, you could increase the space limit
Reactions: VasilisV_3CX
Hi @techguyjason,
Let me know if there is any issue after increasing quota / cleaning.
Jacob.Ive
