Solved Voicemail maximal duration
Lukas Berchten
In the following article 3CX describes that the maximum length of the Combox can be adjusted with the parameter "MAXVOICEMAILDURATION".
https://www.3cx.com/blog/docs/maximum-duration-voicemail/
This parameter is not available in the current 3CX version. The value "MINVOICEMAILDURATION" exists in the parameters and the voice mail gui. Does anybody know how to increase the length of the Combox now?
Interesting. I just checked my Pro license thinking maybe they were hiding the parameter from "standard" users (I hear they do that with some parameters), but I can't find it either. This is a total guess, but maybe they removed this option because the Bing translation service will transcribe a maximum of 2 minutes. That just happens to be the default max duration of voicemails in 3CX. As I said, just a guess.
Hello @Lukas Berchten
As the guide mentions as Step 3 if the parameter is not present you can add it with the desired value.
The guide also states that you should perform this change with due caution and at your own risk.
Reactions: VoIPTools
Thank you for this fast answer, I overlooked that. It works.
Glad to see the issue has been resolved
Bluebox Global
