Voicemail Time Stamp wrong...
Bill Sherman
I'm not sure what the deal is with this, the phone's Time/Date is right, as it displays on the screen. The PBX's time zone is set correctly (both Eastern)
The timestamp as read on the voicemail is off by 3 hours. If I had to fathom a guess, it would be that the Host PC's time is off, but I'd have to go on site to check that.
This is hosted at the customer's office, on a dedicated PC.
Does anyone know for certain where the system pulls the time used for Voicemail time stamps?
From the server/PC. Most sets pick up time from a locally (set) configured NTP server
Hello @Bill Sherman
Which timestamp are you referring to? The filename timestamp or the time in the email?
I have a server with the same / similar issue: -
Call was made - 12/12/2018 12:26:07 PM
Voicemail time stamp is - 20181211232152 (2018/12/11 23:21:52)
Time zone and time on the server are correct.
@YiannisH_3CX - this is not the time stamp of the email, that is also correct.
I noticed this while troubleshooting blank voicemail recordings.
If you open the 3CX Activity Log, and look at the most recent entry, does that time seem to be correct?
@leejor - yea those times are correct
Hello @GlenS
Please note that the filename of the voicemail file is always saved in UTC time so if the time you are getting is UTC, that is correct.
@YiannisH_3CX thanks for the info, that makes a whole lot of sense now.
Glad i could help
Tech_Support
