Solved Voicemail Transcription (BUG OR WHAT ELSE?)
mukkacow
Hello!
After updating 3CX to v15.5.0 I've noticed that at the end of each text transcription the following text is added:
subscripion control (exactly with the spelling mistake)
I assume it's a 3CX problem. Anyone noticed this issue ?
We do not have this issue. Go into "Settings > Email", click Email Templates tab, find the Voicemail template and edit as needed. I personally like the transcript to be at the top so this is how I have mine set.
You have received a new voice mail from "%%CALLER%% -"%%CALLERNAME%%"
%%START_IF_TRANSCRIBE_ENABLED%%
Transcription:
%%TRANSCRIPTION%%
%%END_IF_TRANSCRIBE_ENABLED%%
To: %%EXTNUMBER%%" - "%%EXTFIRSTNAME%%" "%%EXTLASTNAME%%"
Received:"%%DATE%% %%TIME%%"
Duration:"%%DURATION%%"
I have set my template like this:
You have received a new voice mail from: %%CALLERNAME%% (%%CALLER%%)
To: %%EXTFIRSTNAME%% %%EXTLASTNAME%%
Received: %%DATE%% %%TIME%%
Duration: %%DURATION%%
File: %%FILENAME%%"
Message Transcription:
%%TRANSCRIPTION%%
I wouldn't worry - it doesn't work very well anyway. Or perhaps it's just Scottish accents it can't handle ;)
@PreviouslyAsterisk
I agree. It's useless, at least for us, but funny function even if with poor transcription for some languages....
About the "subscripion control" I assume that's a 3CX error because the spelling mistake... but maybe it's from Azure. At this point... who cares! ;-)
Have a nice day!
Hi all,
after doing some debugging I have discovered that the problem was generated by my SMTP tracking...
Problem solved. Not a 3CX issue.
Thanks you
Glad to see the issue has been resolved and thank you for updating the thread with your solution.
Bluebox Global
