Voicemail Translation V20
greatchoice
One of my instances is running out of space quickly. I have this setup for the Google API but it does not seems to be deleting the local recordings as it used to. If i click the delete after i can not send to google for translation
Your disk space is full with voicemails or with recordings?
I think both but how to check what is the recording? If they are not deleting voicemails then they will fill it up. Without a policy to ensure voicemail is deleted in a period of time then how?
You can define to delete voicemails after a certain number of days
Oh so this is not voicemail. Seemed to have a senior moment here. This is recordings then cause i already set that up
Go to Recordings<<Settings and check the Quota, is this full?
No but i raised it to 10GB but it should not be increasing because the remote archiving is on and that should push the calls off right away
It depends on the local disk sapc availability, how many recordings you have and how often you archive.
tdzski5
