VoIP Provider Checker for In-Depth SIP Trunk Analysis
Kevin Attard Compagno
Staff member
3CX Support
Better tools for interop testing your VoIP provider accounts.​
Version 20 Update 8 introduces yet another great new feature with the VoIP Provider Checker for in-depth SIP trunk analysis. 3CX provides a comprehensive list of Supported SIP Trunk Providers. However, if you need to implement a different provider account, the VoIP P...
Can't wait to test this out on the final release!
out of curiosity, would running this give us the green check mark on an imported trunk vs the red exclamation point?
This is not like the firewall checker - it's a troubleshooting tool to gather logs and fix problems, not a certifying tool.
@KyriacosS_3CX is correct its not a firewall checker but our general direction is to move to test interop rather then enforce supported voip providers. We want to move away from this though it will mean you have to do your own troubleshooting of trunks on uncertified ones but this is becoming easier and easier with this tool.
More improvements to it will be made in update 9, including automatic updating of the template to fix issues it found.
I LOVE this idea/thought!
John Rayfield, Jr.
Rayfield Communications
Give us some time and we will also review and rethink the red sign for the unsupported VoIP provider
There is no need for a firewall checker if you are running 3CX hosted or self hosted, the firewall checker only checks the server machine?
AshleyStokes
